Order Ford 8N Parts Online
8n coil
Philip Hendrick
03-11-2003 20:45:02
Just got my n back together and I need to know if the red wire from the battery goes to the + pole on the coil or the - pole on the coil. so then I will know if the wire to the distributer goes to the + or - pole on the coil. This is a 6 volt system with a pos ground thanks philip
Dell (WA)
03-11-2003 23:06:39
 Re: 8n coil in reply to Philip Hendrick, 03-11-2003 20:45:02
Philip..... ...what David said..... .and..... .
Connect your red wire from your ignition switch to your sidemount coil (-) terminal for a positive grounded 6 volt battery..... .Dell
David - OR
03-11-2003 20:53:29
The coil should be oriented the same way as the battery. If the battery + post is ground, then the coil + post should connect to the points, and thence to ground, and the coil - post should connect to the key switch.
If the battery - post is ground, then the coil - post should connect to the points and thence to ground, and the coil + post should connect to the key switch.
