Pto shaft?(hope i get posted this time)
rick craig
03-12-2003 18:52:28
well boys this is my second try, so's here it goes. took the 8N to the car wash today,after the wash i started it up and noticed that the pto shaft wasnt turnin. whats the deal?second question-- if i put her in fourth i have to ride the clutch to get her goin or else she stall's on me. even tryin to get it to go up a little 3 foot hill thats not very steep it will try to stall out on me and this is in first gear. never should of washed her. thanks for the help. be safe. rick craig
Duane
03-13-2003 03:56:48
 Re: pto shaft?(hope i get posted this time) in reply to rick craig, 03-12-2003 18:52:28
Sounds like you got the distributor cap wet. try taking it off and drying it. Hope this helps. Good luck.
Duane
Carl MN
03-12-2003 20:56:40
When you say it stalls; is it the same as turning the ignition switch off or is it a lugging stall were the motor seems like its out of power?
what RPM are you at? idle-1/4-1/2-3/4-full throttle?
Dell (WA)
03-12-2003 20:35:44
Rick..... ...1st question, PTO only runs when it is shifted behind your left heel. You must run your PTO for your 3-point hydraulic pump to lift your arms.
2nd question, too many possibles to be specific. Any wheres from tired engine, bad governor, lean carb, weak sparkies. Inexperienced tractor driver. But yes, it is normal to have to slip the clutch to start out in 4th gear, actually you usually have to slip the clutch on any vehicle when starting out in any gear..... ...Dell
rick craig
03-12-2003 20:45:08
 Re: Re: pto shaft?(hope i get posted this time) in reply to Dell (WA), 03-12-2003 20:35:44
well maybe im doin somethin that i havent noticed. i just dont know what it could be. i aint doin nothin that i havent done since i got it. i though that shaft always turned? tell ya what i'll crank her up tomorrow and go through it real careful and observe what i do, so i can give a better discription of whats goin on. so that pto shaft is hydaulic driven? or direct drive? i'll let ya know tomorrow. thanks be safe. rick craig
Ole Henry - Va
03-13-2003 03:58:30
 Re: Re: Re: pto shaft?(hope i get posted this time) in reply to rick craig, 03-12-2003 20:45:08
Rick, As Dell said, PTO is operated by the little leaver behind your left foot. It's un-engaged at 12 O'clock, engaged at about 2 O'clock. Depress clutch when shifting if the tractor is running.
John A
klf
03-12-2003 19:15:17
Did you get the ignition system wet??
rick craig
03-12-2003 19:22:03
 Re: Re: pto shaft?(hope i get posted this time) in reply to klf, 03-12-2003 19:15:17
ya but as far as it stallin out on me it was doin this before i washed it. thanks. be safe. rick craig
souNdguy
03-13-2003 05:19:16
 Re: Re: Re: pto shaft?(hope i get posted this time) in reply to rick craig, 03-12-2003 19:22:03
As for the pto.. it is direct coupled to the drive train.. but as stated, is engaged by the lever behind your left foot.. perhaps it has always been engaged.. but during washing it slipped out.
You will need to re-engage it to have hyd's as the spinning pto shaft is what turns the pump.
Check your firing order.. an N will run on 2 cyl's and sound ok at higher rpm.. but have no power... My cow used her horns one day and pulled a couple of wires.. I could barely get up the slight grade to my barn before I realized i was a 2cyl 8n. Wires are easy to cross... 1243 is the order.
SouNdguy
