Timing question
Rob
03-14-2003 11:03:55
is it possible for a 1950 8n with a side mount distributor to "jump time"? I realize that it has an internal cam, but is that cam run directly off of the Crank, or is it chain driven?
Dave OH
03-14-2003 20:28:11
 Re: timing question in reply to Rob, 03-14-2003 11:03:55
"MARK" the distributor and rotor position so you can see it before you pull it. If it hasn't jumped time it will make it easier to re-align it as it is a helical type gear. As you put it in it turns.
Dave OH
Hobo,NC
03-14-2003 11:45:32
If it has a fiber gear I have see the fiber part of the gear slip on the hub. The distributor does use a roll pin to retain the drive gear. It could shear. grab the rotor and see if you can spin the dist. shaft. The crank gear uses a key way that could wear allthough That would be the last thing I would suspect. On the dist. gear that would be a side mount type. the front is a direct drive off the cam.
Gary-Miss
03-14-2003 18:56:20
 Re: Re: timing question in reply to Hobo,NC, 03-14-2003 11:45:32
I fixed an 8n for a neighbor a few years ago. He said," I put points and plugs in it and was going across the yard to the garden when all of a sudden it died and the plug wires were all pulled out.' I pulled the distributor, turned it upside down and shook it and handed him the point screw that he had dropped down inside it. I have seen them also strip the teeth off the aluminum cam gear. You can usually tell that because they won't have compression when you hit the starter.
Hobo,NC
03-14-2003 11:41:33
