Resistor on terminal Block?
8N 34343
03-14-2003 17:29:24
I have a front mount dist. The resistor on the terminal block is connected to the "hot" terminal on the inboard side, not connected to anything on the out board side,should the switch to coil wire pass through this resistor? My switch to coil wire goes striaght to the coil.
Dave Smith
03-14-2003 18:55:23
 Re: Resistor on terminal Block? in reply to 8N 34343, 03-14-2003 17:29:24
Go to the link below. It clearly shows the resistor. If you are running the tractor without the resistor in series with the ignition coil, You will burn up the coil.
Dave <*)))><
8N 34343 Thank You Dave
03-14-2003 19:10:59
 Re: Re: Resistor on terminal Block? in reply to Dave Smith, 03-14-2003 18:55:23
I have the Operators and FO-4 and niether show this part of the wiring(resistor/headlites). This answers alot. Why do you think the inboard side of the resistor is connected to the power terminal,that ain't right is it. Mabye the shade tree strikes again?
Joel (So Cal '44's)
03-14-2003 17:32:42
If it's truly 6v... it should pass through the ballast resistor. Is this a new tractor for you?? Curious who wired it in bypass mode...
There are wiring diagrams available at several N sites.
Ciao
8N 34343 YesNewYes6V
03-14-2003 18:30:58
 Re: Re: Resistor on terminal Block? in reply to Joel (So Cal '44's), 03-14-2003 17:32:42
Yes the tractor is new to me, Yes it is 6V,Yes the wiring has been mess with,I have the operator's manual, but the diagram there does not show the resistor,Slould I run the wire marked coil on the switch to the outboard side of the resistor insead of straight to the coil, I left it the way it was because that part of the harness seamed original, but alot of time has past since 48.
