Stretched switch to coil wire!
8N 34343
03-14-2003 19:35:19
Now it makes sense,the switch to coil wire is so tight because it should be hooked to the resistor, not the dirrectly to the switch, which is farther away! I can fix the wiring, but is my new coil damaged. It's been run about 20 mi. like this.
Dave OH
03-14-2003 19:47:34
 Re: stretched switch to coil wire! in reply to 8N 34343, 03-14-2003 19:35:19
Probably not. But you will know soon. Front mount distributors need it. You are talking about a 6v system arn't you?
Dave OH
