Anyone know about dielectric grease?
8N34343
03-16-2003 20:41:49
I'm looking for something to prevent rust on electical conections w/o efecting conductivity. Found some dielectric tune-up grease in the barn, and was wondering if this would work. the instructions say it's for plug wire connections. any other products that will work?
Larry 8N75381
03-17-2003 08:28:21
 Re: anyone know about dielectric grease? in reply to 8N34343, 03-16-2003 20:41:49
John, PA has the best thing to use. That is the grease that MUST be used (electrical code requirement) on all alumnium connections. You can get it at most hardware stores, lots of plases like Lowes, Home Depot, etc. and all electrical supply houses. Comes in a number of Brand names - just ran down in basement and found the tube I have, it is OX-GARD made by Gardner Bender, Inc., comes in a plastic squeez tube like tooth paste - but any one is fine. The electrical parts guy where ever you go SHOULD know what they have for aluminum wire - they GOTS to have it if they sell any aluminum wire!!
I use it for things like the turn signal/brake bulbs on the car where they get exposed to salt corrosion. When you try to take one out to replace it you sometimes almost destroy the socket - not to mention break the glass and bulb base - to get it out. I put a drop on the connections and coat the metal shell - never had a problem with shorting out, tought I am carful not to just smear it on the two connections - just a drop on them. Sometimes use it on 120V house plugs that carry max current to help the conduction. Connections get HOT if there is a poor connection. The heat takes the spring out of the outlet prongs so they do not grip as well - making a poorer connection - making it hotter - making.... you get the idea. It is a down hill slide! Until they can get so hot they catch FIRE!! Had one do that in a computer room where I worked. Melted the plastic around the cord end, chared the outlet! NOT GOOD!!!
I would not use the dielectric grease you found since it sounds like it is intended for high voltage connections i.e. spark plug wires. AND that even makes me suspitious that the grease is NONconductive! That is what we called the greases used for space applications when we DID NOT want connections to carry current. The stuff you found may be intended to keep moisture out ONLY, and also help cut down on leakage of the high voltage spark current. That would work this way. As a dielectric (nonconductor - see dictionary) grease coating on the spark plug wires going into the distributor, it would prevent moisture build up that would allow the spark plug firing current to sneak out. When you have some leakage of the spark current it slowly creates a carbon path - from the plastic being burned a little at a time - that then allows more current to flow allowing greater burning of the plastic, allowing... Said this before - down hill slide! Now because the spark voltage is high enough, it just BLASTS it way through the grease that is in it way going fron the coil to the plug on the first firing and them it is gone from in the path so from then on it is as if the grease is not there. But it is still coating the wire and protecting it.
We KNOW that the aluminum wire grease is a conductor. So I would stick to that for all your low (be it 6V ro 12V, that's low) voltage tractor connections.
Regards,
Larry
Thanks Larry,didn't thinka that-8N34343
03-17-2003 10:03:42
 Re: Re: anyone know about dielectric grease? in reply to Larry 8N75381, 03-17-2003 08:28:21
We'll it I never thought of lookin' in the dictionary,I have a piece of a tube of NoAlOx left over from something.Never thought of using that stuff either but it makes sense.
John,PA
03-17-2003 04:11:14
I tink that the stuff that the electrician industry that you putt on the aluminim wires will probably work fer ya.
Whenever I do ANY control wirin that will be on the outside of a buildin' , regardless if copper or anything else, and, regardless if the connections are contained in a "rain-tite" box, I always insist that an "ANTI-=OXIDENT" compound be pur on the BARE wiring. We use a GREASE. I just don't know what it (the grease) is called anymore. Seems as though the change the names, depending on the times. You migjht check with your local UTILITY company.
RTV compound works for me.
Hope this might help git the week GOI'n. :}))
Farmer Tim *8N15513*
03-17-2003 04:08:18
Do an archive search for a product called Corrosion X or got to www.corrosionx.com We discussed this a while back. Have not tried it yet, I was waiting to do a rebuild and replace all the wiring. Try a marine supply company too. It's used a lot on boats... HTH
Tim Daley
Smitty
03-16-2003 20:55:11
We used dielectric grease in the Air Force to prevent corosian on electrical connection. Be very carefull the Dieltric grease we used was very posinous, not sure if that factor has changed.
Be Safe wear disposable gloves.
Smitty
