Lift arm shaft tolerances
prentice
03-17-2003 07:20:56
Got the lift arm assembly off and dismantled. Lift arm shaft is down to rust and no chrome where it met bushings. Anybody know what the fit is for the lift arm shaft inside the bushings. My thought is to weld-build up missing surface and turn it down to spec. What's spec. Thanks, Prentice
JimNC
03-17-2003 17:26:18
 Re: lift arm shaft tolerances in reply to prentice, 03-17-2003 07:20:56
I don't know what the dimension is but somewhere on either side of where the bushing runs you should be able to get a close measurement. If nothing else put a new bushing in and measure ID of it then turn shaft to a couple thousanths less than that.
