Hi, In PA, most of us use just a few 100 watt light bulbs in a ceramic (porcelon fixture, in most of our barns. Generally this is enough light for milking and overall "barn work". Over the machining area, we use a light at each machine, such as grinders, drill press, etc. Over the work bench area there will always be some sort of flourscent light fixture. Rather than lighting the whole building, perhaps just a flourscent fixture over the work bench area will do. So, just one (1) qualtity flourscent fixture will be better that a bunch of "low end" fixtures. If you mount a standard porcelon fisture with the normat electrical box set-up, you can always mount a duplex out in the box to plug in flourscent fixtures later. Suspend the flourscent fixture by chains from the ceiling, or screw same to the ceiling. I wouldn't put more tnan 8 lights (100 watt) on one wall switch coupled to a 15 amp breaker. High quality (low temperature operation) flourscent fixtures are available at industrial lighing equipment stores. About 100 bucks each. We use this style in our COLD STORAGE ROOMS. Takes too long for the mercury vapor type to get bright. Hope that this helps.
