International harvester propane engines
norweb
03-20-2003 22:12:13
i need some specs for a international harvester 6 cyl propane engine industrial model ub 264. i need the head torque , valve and rocker arm settings. any and all help greatly appreciated. this is for a wind machine to keep the frost off the fruit so it's needs fixing asap!!!!!
thanks.
ZANE
03-21-2003 05:24:35
 Re: international harvester propane engines in reply to norweb, 03-20-2003 22:12:13
Did you try the IH forum on this YT site?
I think you could be close enough for government work though if you torqued the head bolts to about 120 and put the valves on about .015 all way around. This may not be exactly right on the money but should be good for all pratical reasons and will get you going.
Zane
norweb
03-21-2003 21:40:11
 Re: Re: international harvester propane engines in reply to ZANE, 03-21-2003 05:24:35
thank you zane i'll try in . thanks again. ladonna
