2N Cylinder Sleeves
Alan F.
03-22-2003 18:35:30
I am in the process of replacing the head on my 2N and have a question about the cylinder sleeves. While cleaning the old gasket material off the top of the block I bumped the starter to bring up the two down pistons and take down the two up pistons so I could inspect all the cylinder walls. When doing so, one of the sleeves moved up about 1/4". I was able to slide it back into it's proper place with no problem. Can anyone tell me are these dry sleeves or wet sleeves? I checked for coolant in the oil and saw none but the block is pretty well drained at this point. I would appreciate any info on this matter.
Willy-N
03-22-2003 18:55:24
 Re: 2N Cylinder Sleeves in reply to Alan F., 03-22-2003 18:35:30
They are dry sleeves in the Ns. Just on the other side of the sleeve is another wall in the block keeping the water out. Mark H.
Alan F.
03-23-2003 06:16:11
 Re: Re: 2N Cylinder Sleeves in reply to Willy-N, 03-22-2003 18:55:24
Thanks for the information. My dad told me he was 99% sure they were dry sleeves but, it has been several years since had been around one.
Willy-N
03-23-2003 08:12:33
 Re: Re: Re: 2N Cylinder Sleeves in reply to Alan F., 03-23-2003 06:16:11
The Ferguson TO 20s and 30s have wet sleeves and use rubber O-Rings to seal them from leaking and also have much thicker sleeves in them. Mark H.
