Gasket interfering with start-up
ratface
03-24-2003 08:16:20
After front mount tune up and replacing all the gaskets discovered that the gasket between cap and coil keeps my tractor from firing. If I put the cork appx. 1/8 gasket on, the tractor won't fire. Without gasket fires right up. gasket seems ill fitted as it wrinkles some almost if it's a bit oversize. This was a four pack replacement kit of gaskets for the front mount Dist. Does the gasket go up into that small indentation on the bottem of the coil or sit directly on the cap. Without the gasket the coil is somewhat loose and obviously offers no protection. wrong gasket or wrong installation?
Upper Peninsula,Mich
03-24-2003 08:24:46
 Re: gasket interfering with start-up in reply to ratface, 03-24-2003 08:16:20
Gasket goes up into the indentation. If that doesn't work, sometimes you have to extend the spring on the coil just a little bit. Be careful you don't break it off. Good Luck. Ron
Snowplow......yup
03-24-2003 08:58:48
 Re: Re: gasket interfering with start-up in reply to Upper Peninsula,Mich, 03-24-2003 08:24:46
Extend the spring and make sure the gasket is seating properly.
