Order Ford 8N Parts Online
8n Steering timing
Roger
03-25-2003 17:52:59
Does anyone have a sure and easy way to put the steering timing back in place on a 8n ford. Turns a bunch one way and very little the other.
JimNC
03-25-2003 18:07:07
 Re: 8n Steering timing in reply to Roger, 03-25-2003 17:52:59
Roger,
There are five teeth on the square ball nut on the shaft, you have to align the middle big tooth on the left steering sector to the middle of the steering shaft ball nut. Then align the right side. When it is right the steering arms will be pointed down and slightly to the rear. Did you have it apart? Get the FO-4 manual at any tractor supply place $29 (cheap, as Dell WA would say)
roger
03-25-2003 18:19:26
 Re: Re: 8n Steering timing in reply to JimNC, 03-25-2003 18:07:07
A friend of mine had his apart and asked me if I knew how to get it back in place. I thought this would be a good site to maybe get the answer. I've never had one apart. Thanks
souNdguy
03-26-2003 06:41:26
 Re: Re: Re: 8n Steering timing in reply to roger, 03-25-2003 18:19:26
When I had mine apart to repair the streering shaft, I ended up pulling the left sector arm for clearance for the bal nut assy.. and to check the bearing surface.
I believe the 50 8n and the 52 8n have a different setup slightly.. but should be similar enough to line up.
And yes.. the fo-4 manual shows both versions in an exploded diagram. helps you visualize it.
Soundguy
