Rich: I'm just tryin' to get oriented here . . . I'm guessing you're looking at this carb from the side. I'm palming one in my hand right now that I'm getting ready to rebuild, and I'm looking at it like you are. And what you're refering to when you say "the one on the right" with the tension spring is actually the larger screw at the front of the carb. That would be your Power Adjustment Needle (a.k.a: Main Adjustment Needle). That's the one you do the "goose adjustment" that Dell refers to. The smaller screw in the middle of the carb is your Idle Adjustment Needle. That's the one you adjusts at idle. The way you start this adjustment is to run the engine until she warms up. Slowly turn both screws clockwise until you feel them seat. Your engine should die. That's OK, we're gonna git her runnin' again. Now turn both screws COUNTERCLOCKWISE one complete turn off the seat. Start up your tractor. Now follow Dell's instructions for adjusting the carb. Turn 'em slowly when you're making those adjustments, and train your ears to listen for how the engine RPM are responding. If'n the idle speed is too high for you to do the idle adjustment, your can turn the Throttle Lever Stop Screw. I think that's the "3rd screw" you're referring to. It's located on the engine side of the carb on the Throttle Shaft. It adjusts the Throttle Plate clearance. FO-4 manual says to set it until idle speed is at 400 RPM, but unless you got a proofmeter on your tracor or a tachometer, that don't do you no good. A rebuild instruction insert I have says to back out the screw until the Throttle Plate will close tightly. Then turn it until it makes contact with the carb body. THEN turn it 1 1/4 turns in. That should get you to about 400 RPM. No warranty implied here. On the troubleshooting side: If you still lack power you may have some fule starvation. This could be at the cut-off on the fuel tank. Also, the float setting in your carb may be incorrect or you may have a stuck needle restricting fuel entering the carb. May be time for a rebuild. Get you the parts and an Intertec FO-4 manual. I've have good results running a product I get at the marine store. It's an OMC fuel additive called 2+4. It really helps fight the gunk in the fuel system. Good luck, and hope this helps.
