Rusty Rear Rims
Rob
03-25-2003 18:54:28
I have a 1950 8n with six spline rims. The rims are in pretty bad shape around the valve stem. If I have the tire removed off and take the center out of the rim, would it be acceptable/safe to get the area around the valve stem cut out and a patch welded in?
Willy-N
03-25-2003 19:23:36
 Re: Rusty Rear Rims in reply to Rob, 03-25-2003 18:54:28
That is done all the time. You can have it welded up and ground smooth again and a coat of paint on them you will never see it. Mark H.
