Finished(thanks for the advice on the oil)
rick craig
03-28-2003 15:41:16
well 45 rattle cans and about 240.00 dollars later she's finished. dadgum that oil for the tranny and gears is kind of expensive. 6.39 a gallon.well im goin to be busy this summer, but after that i hope to slow down a little. im hopin that there will be some tractor shows at the end of summer or the beginning of fall. sure would like to be able to go to one. maybe even be lucky enough to meat some of ya'll. just kiddin about the 45 rattle cans, although it did take quite a few for three coats.even thinkin about buyin another, if i come across another good deal.fix her up and donate to a good cause or somethin. see ya'll later. be safe. rick craig.
BigDawg
03-28-2003 17:19:43
 Re: finished(thanks for the advice on the oil) in reply to rick craig, 03-28-2003 15:41:16
Rick,
I just changed my engine and tranny oil. It was about $25 for 5 gallons of tranny oil. This was the first time I had ever changed it. (I've had the tractor about 2 months.)
I noticed it was light brown in color and a little milky. The 2 larger plugs had 1/2" of sludge covering them.
Based on the way it looked, I'm glad I changed it.
I put in 80-90 GL-5 and the 3 pt hydraulics seem to be better. I have a 7' blade with some extra weight on it and it now takes about 45 minutes for it to "leak down".
Best Regards,,
Doug
Wsconsin
