Order Ford 9N Parts Online
9n pto shaft removal
Sam
03-30-2003 19:49:16
I need to change the pto shaft seal but Icant get it out,I took out the 4 bolts ,the shaft will pull out about 3 inches,I can see the back of the shaft support bearing,the shaft wont move any farther.
Tyler (MD)
03-31-2003 03:08:08
 Re: 9n pto shaft removal in reply to Sam, 03-30-2003 19:49:16
Once you get it out and it's an early 9N, this may help:
SteveB(wi)
03-30-2003 19:52:25
Pull harder, probably a small mushrooming on the end. Worst case it is really twisted then you'll have to cut it inside from an inspection hole.
Fast Ed Ohio
03-31-2003 00:11:57
 Re: Re: 9n pto shaft removal in reply to SteveB(wi), 03-30-2003 19:52:25
I recall someone a while back had the same problem, the shaft was twisted and he had to use a sawsall to cut the shaft and replace it , I pulled mine last year, no problem .
