Rear Hub Wear
Ron (8n509270)
04-02-2003 09:45:01
What do you look for as far as wear goes on the rear hubs? With every thing apart the hub will slide all the way onto the axle with no effort, is this normal? What else should I look for? The bearing looks new but was dry, should packing these be routine maintanence?
Thanks
Ron
Gary-Miss
04-02-2003 18:09:31
 Re: Rear Hub Wear in reply to Ron (8n509270), 04-02-2003 09:45:01
The hub should not slide on the axle so far that the splines are sticking out. If it does, the hub is usally worn out. They are available for around 50bucks
Never mind found the anwer Ron
04-02-2003 11:38:15
