Order Ford 8N Parts Online
Neg grounded 8n
Rob
04-02-2003 20:13:35
Someone along the way has hooked up my 6 volt battery to positive ground. What is involved in switching my side mount distributor, 8n, back to positive ground. I understand that I need to polarize the voltage regulator, but will this polarize everything? Like the coil, generator, and starter?
Thanks in advance for the help!
that and==bj/8n.mt
04-03-2003 05:43:43
 Re: neg grounded 8n in reply to Rob, 04-02-2003 20:13:35
If your ammeter reads right now you will need to reverse the leads or learn to live with it reading backwards. Check the coil leads on the side mount coil since if they were done correctly when polarity changed they will now be backwards too. Repolarize the generator. Any other accessories that might be polarity sensative--I saw an n series with a radio once--need to deal with that too.
Your mileage may vary
bg
04-02-2003 21:10:01
just switch it around, polarize the generator, and you'll be good to go.
