Hydraulic pump for 801 engine very differant???
9N141
04-03-2003 14:20:41
172 cu.in. indust. engine in Jacobson gang mower. I bought this for the engine, the mowers & hyd. cylinders are gone. My question: the hyd. pump runs off the cam as usual with same bolt pattern, & has a 5 gal. resvoir, this pump is completly diff. from the regular pump- how do I calc. the vol. & pres., etc. Thanks. P.S. the hyd. were only used to lift gangs, not run hyd. motors. BURT.
Fessman
04-03-2003 15:33:26
 Re: Hydraulic pump for 801 engine very differant??? in reply to 9N141, 04-03-2003 14:20:41
Burt,
What size are the ports??? Both suction and pressure.
Jim.UT
04-03-2003 14:48:18
third party image
There were 2 different hydraulic pumps used on the 172 cu in engine. The early x00 series' had a vane pump like in this picture. The later piston pump was round. Is yours different from either of those two?
I'm sorry I don't have the answer to your original question about calculating volume on the pump. If it's a vane pump, that info may still be available in Ford manuals somewhere.
9n141 ----its very differant
04-03-2003 15:24:34
 Re: Re: Hydraulic pump for 801 engine very differant??? in reply to Jim.UT, 04-03-2003 14:48:18
Thanks Jim. This pump is totally diff. than those you have mentioned, I believe it is probably not Ford, but designed for special ind. uses. More help please. BURT.
