pat
04-04-2003 21:00:23
Re: Hydraulics stuck in the up position-help! in reply to Rochester (WA), 04-04-2003 18:48:58
yup sounds like what happened to mine once while backlade was attached while moving a lot of snow, and I ended up driving up the "hill" of snow,, I copuild not get it down manually at all. well I had to do waht was prescribed, go in the side plate, and get my hand way down in the "cold at the time" hyrdraulic oil, and release the control valve manually, then the blade came down normally, you might as well check to be sure your arms are connected correctly to the "t" on the bottom, iof they get out of alignment, that can cause this problem, as far as hurting your hydro's with the implement up, I dont see any worries there, it is stuck up there , there is no pressure holding it up, but be very careful when the presure releases, it could come down in one swoop, or may do like my blade nice and controlled, but be on the safe side and keep all limbs and feet out of the way, good luck,Pat
