Dearborn 10-80 plow
AZglide
04-09-2003 14:57:48
Does anyone know the aproximate weight of a Dearborn 10-80 two disk plow? Looked through the manual and the archives, found some good information as usual, but the weight isn't mentioned. It still has the weight mounted.
Thanks.
Ultradog MN
04-09-2003 20:59:55
 Re: Dearborn 10-80 plow in reply to AZglide, 04-09-2003 14:57:48
I got to see a 10-80 up close and personal last spring. It was for sale at an auction but it went way out of my league.
I have a standard 2-14 Dearborn moldboard plow. My guess is that it weighs about 150+ lbs.
I bet that a 10-80 would double that.
hth
Jerry
9N141
04-10-2003 11:49:49
 Re: Re: Dearborn 10-80 plow in reply to Ultradog MN, 04-09-2003 20:59:55
i HAVE THE DISC PLOW, THE STANDARD 2-14 WIEGHS APROX., 250-275 LBS., AND DISC PLOW i WOULD GUESS AT 450-475 LBS. i HAVE USED BOTH ON 8N THE DISC PLOW IS MUCH HEAVIER. THE WT ON FRONT OF DISC PLOW LIKELY WIEGHS 200 LBS. THE DISC PLOW WORKS REAL GOOD. BURT.
AZglide
04-10-2003 15:43:39
 Re: Re: Re: Dearborn 10-80 plow in reply to 9N141, 04-10-2003 11:49:49
Thanks for the responses. Once I get it adjusted so it will follow the NAA rather than trying to pass it on the left all the time I think it will be OK. Might even try it behind the Farmall 140 if it will pick it up!
