Replacing radiator....
9n in mn
04-14-2003 08:18:06
I was in the process of replacing my radiator when I posted a question wondering if I needed to take my hood off to do so. I got replies saying yes, I did.
Last weekend I began the project. I have found, at least with my 9n, that I could lift the hood up far enough on the end to be able to get the carriage bolts on the bottom set in without damaging any part of the hood. I didn't have much gas in the tank, so that helped in the lifting. All I took off was the shroud and the grill.
Is there anything I could have missed in not doing it with the hood off?
I have used the tractor all ready for several hours. It runs around 160* or even a little lower...
Evil Steve
04-14-2003 08:30:52
 Re: replacing radiator.... in reply to 9n in mn, 04-14-2003 08:18:06
As long as you replaced the rubber pads under the raditator s/b okay, although I would worry I'd damaged fuel lines by moving the hood like that. Recheck 'em or you might be in for a fire.
That temp is too low and means you must either have a stuck (open) t-stat or none at all. Install a good one and run at 190* as you are supposed to. Your tractor will run better and you won't foul plugs as often.
uh . . . Dell (WA)
04-14-2003 08:44:44
 Re: Re: replacing radiator.... in reply to Evil Steve, 04-14-2003 08:30:52
Steve..... ...sorry buddy, N-Thermostat is 160*, and I agree N's need thermostat to run right..... ...respectfully, Dell
Evil Steve
04-14-2003 10:17:06
 Re: Re: Re: replacing radiator.... in reply to uh . . . Dell (WA), 04-14-2003 08:44:44
Ouch! Yer right! Got my dumb@ss hat on today.
Hobo,NC
04-14-2003 09:41:34
I second that! (Dells Reply)
