Order Ford 9N Parts Online
9n running rough with little or no power
9n in mn
04-14-2003 08:26:29
I am posting this message so it can possibly help others in the future.
I have a 9n that seemed to get 'fatigued' or had little or low power after getting warm. It acted like it was getting too much gas because the only way it would stay running is by backing off the throttle. It also could not handle a load, it would idle smoothly though.
I ended up consulting this board and replaced the ignition coil that I had laying around from a previous reccomendation about a previous problem. That corrected the problem and since it has run for several hours!
bg
04-14-2003 08:34:56
 Re: 9n running rough with little or no power in reply to 9n in mn, 04-14-2003 08:26:29
Generally, it's bad to generalize, but when performance starts deteriorating when the engine gets warm, it generally means that some electrical component is breaking down. Heat does bad things to electrical conductivity. That's why computers have fans and heat sinks.
