Order Ford 8N Parts Online
TO30 vs 8N
Rick B.
04-17-2003 15:26:31
I have been looking at a TO30 for sale and am also considering an 8N. What is your opinions on things such as parts availibilty and cost, engine reliabilty, weak points and so on. What say you
Thnx Bman
Forty Man
04-17-2003 20:36:31
 Re: TO30 vs 8N in reply to Rick B., 04-17-2003 15:26:31
Rick,
The TO-30 was made in the USA . The TE series was made in England . The TO is most common in USA but there seem to be a lot of TE series in Canada .
The TO-30 had a Continental Z-129 engine . Look for the casting numbers on the left side of the block just above the oil pan .
I have a 2N and also a TO-30 . The Fergie is heavier and more powerful and parts are pretty readily available at local MF dealer though they tend to be a little higher priced than N parts . On the down side , the blocks tend to crack if overheated but they can be fixed . I seem to be one of the lucky ones as mine is not cracked . Also , there is no position control but you can add a Zane Thang .
Be sure and check for the cracked block ( coolant in oil or oil in radiator ) .
You will really appreciatte the extra power of the engine and the extra weight helps with traction .
Good Luck !
Ford Man
Ford Man
04-17-2003 20:39:37
 Re: Re: TO30 vs 8N in reply to Forty Man, 04-17-2003 20:36:31
Whoops ! Name should have been Ford Man .
Hunter
04-17-2003 17:49:19
I've owned both, probably would go with the TO30 and a zane thang. The TO has about 28-30 hp and parts are readily available, 'course ain't nothing wrong with the N.
Ray
04-17-2003 17:12:13
I've got a nice 8N I'm going to sell,it has the
8 speed step down tranny,really works good with
a tiller.
john
04-17-2003 16:16:47
i was looking at a to 30 and a dealer told me to make sure it has a contenintal engine..... not a perkins
Ole Henry
04-17-2003 15:55:37
I did the same before buying my 8N. Was told to check if it was made in England. Check serial plate in front of steering wheel (I think). If serial no. begins with "E", don't walk, RUN. Parts are hard to get, at least not as easy as 8n parts. Don't know this for sure, but was told.
Again, I think, the TO30 is a little bigger, had overhead valves and has a little more horsepower than the 8n.
Hope this helps,
John A
Rich,NJ
04-17-2003 16:00:23
 Re: Re: TO30 vs 8N in reply to Ole Henry, 04-17-2003 15:55:37
Didn't I read somewhere that Fergies have Triumph engines? My 59 TR3A was rated at 105 HP. That should be quite a handfull in the east forty.
Regards, Rich
Ole Henry (Va)
04-17-2003 16:11:41
 Re: Re: Re: TO30 vs 8N in reply to Rich,NJ, 04-17-2003 16:00:23
Yeah, you'll be in the west forty before you can tromp on the brakes!
John A
