Inner Axle Oil Seal Removal
Rick
04-21-2003 18:37:20
I'm having no success at removing my late '52 8N axle oil seals - the inner ones inside the axle trumpets. I been trying to use a slide hammer, but it keeps slipping off. Any suggestions? Thanks.
Gary Beyer
04-23-2003 11:06:15
 Re: Inner Axle Oil Seal Removal in reply to Rick, 04-21-2003 18:37:20
I feel your pain! I went through this a few weeks ago. I had mine totally mangled with a regular seal puller and was in the process of trying to collapse it with only partial success. That damn thing is strong! I was finally able to grab hold of part of the mangled metal with a vice grip pliers and pry it out. It came out really easily and I wondered why I hadn't tried that earlier. Give it a try.
Gary
Ron (8n509270)
04-21-2003 19:11:51
I used a punch to put a hole in the retainer face. Once this was done used a screwdriver to force it to collapse. Took about 10 minutes per side.
hth
ZANE
04-21-2003 19:11:39
Sharpen a nail set or punch and drive it into the outer edge of the seal to make a hole just a little smaller than a big sheet metal screw. Screw it in the hole and use a pair of vice grips to pull it out.
Or you can do like I do and weld a screw to the slide hammer and then screw it into the hole in the seal and snatch it out.
Do you realize what that little piece of information is worth????? ? If you try it you will know.
