Swinging drawbar hitch pin, pic
Philip
04-22-2003 06:04:06
third party image
Would someone please supply dimensions of this swinging drawbar hitch pin so I may make one? These appear to be hard to find. Thank you. Philip.
RAY OH
05-19-2003 21:39:10
 Re: swinging drawbar hitch pin, pic in reply to Philip, 04-22-2003 06:04:06
p[n is 3 9/16" long x 1 1/8" od cross pin is 1 5/8" x 1/4" od from flat bottom 2 1/2" to 1/4" cross pin
Do Swinging Drawbars Work Good, Upper Peninsula, Mich
04-23-2003 07:27:34
I have never used one and wonder if they work as good as the regular drawbar on the lift arms? How much do they cost? Where have you purchased them? Ron
Dell (WA)
04-23-2003 09:01:21
 Re: Re: swinging drawbar hitch pin, pic in reply to Do Swinging Drawbars Work Good, Upper Peninsula, Mich, 04-23-2003 07:27:34
Ron..... ...ONLY the 8N is swinging drawbar capable, because the 2N/9N don't have the built-in bolt-holes under the differential like the 8N does for attachment. The swinging drawbar is also a "stronger" puller.
The 11 hole drawbar can be "jacked-up" when you back-up, the swinging drawbar doesn't do that.
Swinging drawbar kit about $100, available at most Ford tractor parts supply emporiums..... ..Dell
Matt@MI
04-22-2003 17:30:10
Diameter 1 1/8"
Length 3 1/2"
Little pin 3/16" dia.x 1 5/8" long
Little pin is 2 5/8" from square end
Hope this helps.
Thank you Matt, Philip
04-23-2003 05:02:31
 Re: Re: swinging drawbar hitch pin, pic in reply to Matt@MI, 04-22-2003 17:30:10
cyr
04-22-2003 16:28:18
Bought one last year from Just 8N's. It was under $20 and works and fits fine. HTH.
cyr
04-22-2003 16:28:09
Gaspump
04-22-2003 07:19:01
Bought one a year ago at the local NH dealer $28.
Philip
04-22-2003 08:50:24
 Re: Re: swinging drawbar hitch pin, pic in reply to Gaspump, 04-22-2003 07:19:01
Do you have the FNH part number? I asked my FNH dealer and he said it was not available. Thank you. Philip.
souNdguy
04-22-2003 11:10:54
 Re: Re: Re: swinging drawbar hitch pin, pic in reply to Philip, 04-22-2003 08:50:24
That is the stock response my NH dealer has about any 'vintage' part.. sometimes they don't even blink.
Soundguy
raytasch
04-22-2003 10:21:26
My book shows the basic part # as 804.
ray
