Rick..... ...original starter relay goes "click", replaced the battery....no help....replaced the starter relay.....NOW it doesn't even click. Then you wonder if voltage regulator is reason new starter relay does't click. Think about that. Didn't you just replace your battery? Then you wonder if starter is reason new starter relay doesn't click. Think about that. The relay gotta click to make the starter go roundy-round, not the other way around. Think about what is common between a new battery and a new starter relay. Thats right, the big thick as your thumb, battery cable. They can be BAD underneath the insulation or underneath the moulded connectors. I'd replace it. Remember the 6 volt mantra: "Keep'em clean, bright, and tight" and don't be fer usin' enny of them thar wimpy battery cables, use 'arry chested 1-ought (thick as yer thumb) battery cables..... .....Dell
