Ospho
Rick
04-27-2003 16:36:54
I am not able to immediately prime the parts of my 8N after sandblasting. I live in a high humidity climate and have found that brushing the parts with "ospho" is protecting them from rusting while the parts are waiting to be primed. Will I encounter any problems with primer and paint after using OSPHO? I plan to use a synthetic enamel paint. Thanks.
9n'er
04-27-2003 17:13:43
 Re: Ospho in reply to Rick, 04-27-2003 16:36:54
In general...no.
But, if you put it on the metal and it powders-up and streaks, that's fine, but just before you prime, wash it down with a diluted mild dishwashing soap to remove the powder residue. That powder substance (can't recall the name) will not let the paint/primer adhere as you can imagine. Dry it, use a heat source if really high humidity, to remove the moisture, prime and paint.
