Oil bath air filter always full of water. Finally solved it.
Rob
04-30-2003 03:36:52
The "dusty condition" air cleaner was extended up through a 2" hole in the hood. I found a black rubber toilet tank gasket at the hardware store.
I removed the weatherhead, slide the gasket over the extension tube to the hood and added a bit of silicone adhesive to hold it in place on the hole.
Problem solved. $1.78/Ace Hdwe.
