Order Ford 8N Parts Online
8N crank shaft
44
04-30-2003 11:54:45
Does the Ford 9N ,2N ,8N use the same crank shaft
I have a crank shaft with 9N stamped on it or were they all stamped 9N I would like to use it in my 8N If it will bolt
in with out any changes
ZANE
04-30-2003 18:52:16
 Re: 8N crank shaft in reply to 44, 04-30-2003 11:54:45
All N crankshafts are created equal! They are all the same. That is if it is standard size journals.
Many have been reground and are different journal sized but they will fit any N engine when equiped with the appropriate size bearing.
Dell (WA)
04-30-2003 13:05:38
44..... .....my N-Ford Master Parts Catalog lists p/n 9N-6303-A, crankshaft, standard, 9N, 2N, 8N, 39-52 (all). May I refer you to the I&T FO-4 manual ($29 cheap) for crankshaft journal size specifications..... ....respectfully, Dell
Hobo,NC
04-30-2003 13:03:59
I beleive? Thay are all the same. I put a 46 in my 50 W/Front mount dist.
