I've got a late model 8N with the side mount distributor. I've owned it about 10 years. No engine problems until now. I drove it out of the barn last month and got about 300 feet away when (like an idiot) I looked at the oil pressure gauge for the first time. Of course, it read zero. zilch. nada. I'd had this problem before - the oil pump had lost it's prime. Only I had always caught it before I started driving. So I got the oil pump working again (primed it), but the oil pressure fell to only 20 pounds when the engine's hot and it fell to zero at idle. It always had at least 10-15 pounds at idle before.So, I pulled the engine and took it apart today, expecting shot rod and/or main bearings. Guess what? Rod bearings look excellent, mains look good. Lots of bearing material, some scratches, some wear on the mains, but it all looks good. I don't have any way to measure the clearances, but they can't be too bad. Also, (although it doesn't have anything to do with oil pressure) the pistons had minimal wear and there was no ridge at all in the cylinders. The oil pump gears looked good (3/4" gears). So, why do you think that the oil pressure went bad? Is it possible that the cam bearing surfaces are bad? Or maybe just the oil pump? I'm thinking about having the cylinders measured and if they and the pistons are OK, then just going back with standard size piston rings. (4-ring pistons). The crank will need to be turned due to ridges on it. Any suggestions?
