Rear Tire Removal
Rick
04-30-2003 16:49:45
I have tried, with no success, to remove the rear tires from my 8N rims. The tires must be replaced and I need to sandblast and paint the rims. What is the best way to remove the tires? Can they be cut off?
Jon
05-01-2003 06:34:26
 Re: Rear Tire Removal in reply to Rick, 04-30-2003 16:49:45
Rick,
Never done it myself but this web site makes it look simple. Just need lots of elbow grease and the right tools.
Good luck
http://www.gemplers.com/a/pages/tchange.asp?UID=2003042913565563&GEN2=&GEN3=&GEN9=0
Dell (WA)
05-01-2003 00:25:08
Rick..... ....take your tires into a real heavyduty tire shop like truckers use and pay them, they've got the experience and the HD eqmt to do it and will NOT charge you very much. Infact will be "free" if you buy new innertubes, $25 cheap (grin)..... .....Dell
Tommy (TX)
04-30-2003 21:24:12
Like George, I have used a Sawzall to remove the tires from the rims. The beads on my tires are rusted (seem welded) to the rim. I'm actually thinking about taking my rear tires to the shop to be removed, but I may attempt it with the Sawzall, wedge, and sledge. FWIT
Tommy
George Willer
04-30-2003 17:28:30
Rick,
Two weeks ago I took my rear wheels to a shop to have the tires removed so I could do the rims and save the tires. I was not able to break the beads myself.
I wanted to take the rims to a sandblaster so I also sawed the tires from another pair of rims so I could take them all at the same time. I cut both sidewalls all the way around on both sides with a sawz-all. The remaining beads were easy to get off.
I intend to mount the old tires on the refurbished rims using new tubes after rinsing any remaining calcium residue.
George Willer
