Save time: remove muffler and drain trans/hyd fluid simultaneously!
=-=-= Mr. Bill
05-01-2003 13:03:46
The N-series muffler (horizontal type) is supposed to be attached to the center housing by a clamp which is held on by a nut on a stud. On my 8N, someone had replaced the nut and stud with a bolt.
Just a trivial change, right? When I removed the bolt I got a nice gusher of trans/hyd fluid. Very entertaining. I imagine there's some ghostly farmer in the afterlife watching me and chuckling "Ah KNEW Ah'd git someone with that bolt trick one o' these years!"
Lee
05-01-2003 14:50:28
 Re: Save time: remove muffler and drain trans/hyd fluid simultaneously! in reply to =-=-= Mr. Bill =-=-=, 05-01-2003 13:03:46
Yep, he's up there just gigglin' like a little girl. Thanks for sharing that story. Gave me a good chuckle. I just hope it wasn't too big of a mess for you. It sounds like you're handling it well.
Later, Lee
Jim.UT
05-01-2003 13:29:22
After the initial cussing the only thing you can do is laugh!
Good one!
