Compression
rj
05-01-2003 19:10:44
what is the correct way to perform a compression check on a ford jubilee.
JimNC
05-01-2003 19:21:47
 Re: compression in reply to rj, 05-01-2003 19:10:44
Remove all the plugs. Remove coil wire. Throttle wide open. Crank engine over til needle on gage stops moving, usually 6 to 10 revs.
Jim
Dell (WA)
05-02-2003 00:46:35
 Re: Re: compression in reply to JimNC, 05-01-2003 19:21:47
RJ..... ..what Jim said..... ...and..... ...
The NAA Red Tiger OHV engine, 134 cu/in, 31.14 hp, 6.6 compression ratio, Ford specs: 120 psi min dry. Don't forget to do a "wet" test too. (1 squirt of oil in sparkie hole after the dry test). Write your compression numbers down..... ....Dell
