Axle Oil Seal Position
Rick
05-02-2003 06:09:29
I'm replacing both the inner and outer axle oil seals on my '52 8N. Do the seal protrusions or "lips" go to the inside or outside of the trumpets? Thanks much.
Lee
05-02-2003 08:55:43
 Re: Axle Oil Seal Position in reply to Rick, 05-02-2003 06:09:29
Almost any oil seal is designed so that the "lips" go toward whatever it is that you're sealing in. The flat or flatter side is normally to the outside where you don't want the oil to go. Hope this helps.
Later, Lee
