Order Ford 8N Parts Online
8N Steering Box Oil Leak
Rick
05-03-2003 19:27:15
I just overhauled my '52 8N steering box. I now have steering box oil seeping from between the box and the steering tube assembly (i.e. from between the shims). Is the remedy to disassemble and place gasket sealer between each of the shims? Thanks in advance.
souNdguy
05-03-2003 21:19:06
 Re: 8N Steering Box Oil Leak in reply to Rick, 05-03-2003 19:27:15
I think you may just have it too full. The fill plug is below the tube/coverplate.
I guess if you gasket sealed the shim area, you would have to change your # of shims to get top/bottom play out.
Any ideas from the gallery? I rebuilt mine a while back.. but just filled to the fill plug, plus a little for the bearing in the tube...
Soundguy
