Oil pressure
paul
05-04-2003 03:00:04
what should the oil pressure foe a 9n/8n?
Dell (WA)
05-04-2003 08:04:31
 Re: oil pressure in reply to paul, 05-04-2003 03:00:04
Paul..... ..what Zane said..... ....and..... ..
The N-Engine has a pressure relief valve thats about 35 psi max. So depending upon condition of engine vitals and oil tempature can range from 10-35 psi.
And if you're worried, new oil pressure gauge is only $10.
Remember: only about 15% of the oil gets filtered. But change it at least once a year..... ..Dell
ZANE
05-04-2003 04:53:31
I have seen Ns run O oil pressure idling when hot and never have any symptoms of trouble.
As long as the oil pressure comes up when started to a point that it can be read on the gauge and the engine is not knocking or squeaking the oil pressure is suffecient.
May not be something to write home to mother to brag about but it will run for who knows how long.
Henry knew his stuff when he built the crankshaft with plenty of excess bearing area to carry the relitavely small power load.
That's one reason these babies are still going strong with absolutely no bearings in the camshaft bore. Lots of overkill on the bearing area.
