Exhaust Manifold
Pitch
05-06-2003 17:38:41
I blew the gasket on my exhaust manifold today. Now Mr.Murphy seems to sit on my shoulder whenever I do any mechanical work. What kind of luck have you guys had with removing the manifold nuts without breaking the studs? I know that they are supposed to be brass nuts but I have no idea of the tractors history before I got it 5 yrs ago.
RoN of ohio
05-06-2003 19:35:21
 Re: Exhaust Manifold in reply to Pitch, 05-06-2003 17:38:41
I just replaced mine and had no problems. Those brass nuts don't seize or rust but getting that muffler clamp in just the right position does take some time. That air cleaner pipe won't go on unless that clamp is turned perpendicular to the motor.
MikeC
05-06-2003 18:36:14
I would spray them with something like PB Blaster just to give you an extra edge. However, since they are brass they tend to come off easy.
DC
05-06-2003 18:19:18
Just replaced mine with no problems, 48 8n with every farmer fix on it you can imagine. But it did still have the brass nuts
