Adjusting front wheel bearings?
8N34343
05-08-2003 07:07:18
I just finished assembling the front hubs with new bearings and dust seals,but the seals are so tight against the spindle I can't tell if the bearings are adjusted right. I made sure the seal was setted and greased the face good,checked the part #. I know an N will only do 18mph. with a tail wind, but dont want to replace them again. Any help?
Claus
05-08-2003 07:30:52
 Re: Adjusting front wheel bearings? in reply to 8N34343, 05-08-2003 07:07:18
Tighten the nut to about 10 ft lbs and back off to the last cotter pin hole. There is no preload on these bearings. Did you put a little grease on the seal to facilitate easier rotation of the wheel?
Happy Motoring
Claus
