The other guys have good answers. I'll tell you what I did. I had some nickel to quarter sized rust outs, as well as pin holes on my 8n and NAA. I sanded both sides of the hood down clean, pas tthe rust, around the hole, and then cut some metal flashing ( tin? ) and jbwelded it to the back of the hood as a backing for the filler. On the larger hole i used more jbweld as filler.. in the pinholes I used bondo. Do yourself a favor.. if you do the jbweld thing.. get the jb qwick weld.. mix it good and it wont run.. sets fast, gets hard, and sands smoother than bondo. ( harder to sand than bondo. ) I had to do some repairs to the ribbed area on the hood in front.. bondo, lots of patients, and a few types of sand paper and a small form i made worked great. ( I made a form out of epoxy putty on a good section of the ribbing, then used this form with light sand paper to sand the bondo'd ribbing down to almost exact conture. Not 100% perfect.. but looks good at close glance.) Soundguy
