Order Ford 8N Parts Online
Torque spec's for the 8n
Ronald E. Gates
05-13-2003 16:33:06
I have just replaced the manifold and need the torque spec's if possible. I would like to find all the torque spec's if anyone knows where to get them. Thank you for your help! Ron Gates Saint Augustine,Fl.
MikeC
05-14-2003 03:55:56
 Re: Torque spec's for the 8n in reply to Ronald E. Gates, 05-13-2003 16:33:06
The FO-4 manual has many of the specs you are looking for.
Ron Gates
05-14-2003 13:49:36
 Re: Re: Torque spec's for the 8n in reply to MikeC, 05-14-2003 03:55:56
Thank you all for the info on the torque for the manifold. Thanks for the info on the FO-4 manual- MikeC. sincerely Ron Gates
Mountainman
05-15-2003 00:30:38
 Re: Re: Re: Torque spec's for the 8n in reply to Ron Gates, 05-14-2003 13:49:36
Make sure you use the brass nuts, that way you won't pull the studs out of the head when you next remove the manifold - I think the brass nuts are torqued at 27 ft lbs. I've seen it in the archives.
hth
N - joy.
Mountainman...CA
Rob
05-14-2003 03:36:58
soft 7/16"-14 is 32 ft-lbs fine thread is +9% or 35 ft-lbs. Source: "Pocket Ref." shirt pocket book available at checkout stand at a Kansas City Ace Hdwe store. 540-somepages of specs on everything from "Ten" radio codes, Clark degrees of hardness, glues, solvents, paints & finishes, physical constants, wire amperage, to signs of the zodiac.
Rob
05-14-2003 03:42:12
 Re: Re: Torque spec's for the 8n in reply to Rob, 05-14-2003 03:36:58
That's a soft steel torque so brass is likely even less.
Fast Ed Ohio
05-13-2003 22:25:43
I replaced my manifold a few years ago , before I had a manual , snug is good , but not to tight. Brass nuts are great.
duey
05-13-2003 21:43:56
My manual says 50 to 55 ft lbs for the nuts attaching the HEAD. The manifold doesn't need near so much, especially brass nuts. I don't have the number but 50 is too much... duey
Larry
05-13-2003 17:01:17
According to Ford Motor, torque from 40 to 50 foot pounds with a new gasket.
Regards
Ron Gates
05-13-2003 19:20:22
 Re: Re: Torque spec's for the 8n in reply to Larry, 05-13-2003 17:01:17
Thanks for the spec's Do you know where I could get all the torque spec's for the tractor?
lrb111
05-14-2003 08:46:33
 Re: Re: Re: Torque spec's for the 8n in reply to Ron Gates, 05-13-2003 19:20:22
Here's a bunch of them... hth
