Thanks to all who responded to my post below!Well....this morning, I figured I'd give the tractor one more try....wait for it to quit, and use the old test light to check electrics, as you guys had me convinced that the problem may be electrical. Well.....I didn't even make it once around my property- it quit after 5 minutes this time, at the point furthest from the house of course! I used the test light to confirm that I was getting power to the coil (I was)- I checked the out-put side of the coil with the key on, and the light lit (is that good or bad?) Let the tractor sit, and took mom to town- came back, ready to drive the tractor home....and it wouldn't stay running at all- I could play with the choke....and it would run a few seconds....and once I tapped the float bowl, and it ran for almost 30 seconds! -and I know it's something small and stupid...but man! is it annoying. The rebuilt carb worked great when I got it- all last summer- and I started her up every 2 or 3 weeks during the winter...then, come this spring....nothing but trouble!
