Box Blades
R.M. In AL.
05-13-2003 21:10:33
There has been lots of talk lately about the box blade,some use the teeth and some don't,like me I guess its according to if you are taking down a hump or fine grading.I was just wondering what you guys use for weight on your blade,or if you use any.I use a 16"X 16"Concrete flue block. in the center of the blade.I suppose it weighs about 80 lbs.It seems to give just a little "Down Pressure" and very affordable...R.M. In AL.
E. Ray
05-14-2003 03:48:03
 Re: Box Blades in reply to R.M. In AL., 05-13-2003 21:10:33
I don't use any extra weight on mine. If I am not picking-up enought material to spread, I shorten the top link.....E. Ray
Fast Ed Ohio
05-13-2003 22:55:22
Whatever floates your boat .
R.M. In AL.
05-14-2003 21:00:47
 Re: Re: Box Blades in reply to Fast Ed Ohio, 05-13-2003 22:55:22
What do you normally use Ed. I have one of those Atlas Blades.I guess it would be considered medium or light weight.Not near as heavy as Jims,it works ok with the teeth but when grading close it wants to ride over the dirt or gravel sometimes..I guess the railroad rail is also a pretty good idea huh..R.M. In AL.
Jim.UT
05-13-2003 21:43:18
I use a 7' LandPride box blade. It weighs over 400 lbs all by itself. I've never needed any extra downforce for it to work.
Pj 8n Wy
05-13-2003 21:16:04
I'm in the process of building a box blade and plan on a piece of railroad rail (136 lBs per 3') for xtra weight. Have used one on my back blade for years and it really makes a difference. Good luck with yours.
