Drip.....drip.....drip
Ron from IL
05-14-2003 07:19:10
Last night, I went out to mow along the edge of the driveway (1/3 mi.) with the 2N and belly mower. While doing the usual checks (oil-gas-antifreeze) I happened to look down just as a drip fell from the cotter pin below the clutch housing. About 20 secs. later, another fell. I checked the oil and it was down a little, but not too bad, so I topped it off and mowed (hour and a half). When I got done, the oil, heated up by this time, was dripping regularly (a drop every coupla seconds). Oh well, guess it's time for crank seals! Is there a one-piece for the rear? I have the front seal number (NAPA #550199), but don't recall if there's one for the rear. Anyone know? Thanks, as always.
Ron
Lee
05-14-2003 09:42:18
 Re: Drip.....drip.....drip in reply to Ron from IL, 05-14-2003 07:19:10
They're s'posed to do that, ain't they !!!
Just funnin' ya ! I hope your repairs go well.
Later, Lee
jimmac (WA)
05-14-2003 07:34:07
Ron, Im certainly no expert but that could allso be the front seal in your transmission leaking. HTH Jim
Larry
05-14-2003 07:53:04
 Re: Re: Drip.....drip.....drip in reply to jimmac (WA), 05-14-2003 07:34:07
You are correct. Ninety percent of the time it's the seal on the transmission mainshaft. Cheap part and easy (after you split the thing apart).
Regards,
L and C Ranch
Ron from IL
05-14-2003 08:26:37
 Re: Re: Re: Drip.....drip.....drip in reply to Larry, 05-14-2003 07:53:04
Thanks guys!
I'll check into it--I didn't smell the oil to see if it was transaxel fluid. Pays to be thorough!
Ron
Jim(FL)
05-14-2003 10:38:14
 Re: Re: Re: Re: Drip.....drip.....drip in reply to Ron from IL, 05-14-2003 08:26:37
Ron, If it is the tranny seal, be prepared also to R & R your clutch/pressure plate assemble. The shaft end of the internal tranny housing unfortunately ends right at the clutch/P.plate.
This means at least a clutch disk replacement due to the tranny fluid dripping down on it.
I am more inclined to think it is an engine rear main seal leak, because you have not complained of a sticky or mis-operating clutch.
Jim
Ron from Il
05-14-2003 10:59:59
 Re: Re: Re: Re: Re: Drip.....drip.....drip in reply to Jim(FL), 05-14-2003 10:38:14
Jim,
My clutch has been questionable for some time. It's not sticky, but I have no adjustment left on the rod. When I get in there, I'll do the pressure plate, pad and T.O. bearing along with the seal(s).
Ron
