Rear axle retainer
Pj 8N Wy
05-17-2003 16:07:14
I am rebuilding the rear end on my 8n and am wondering how much wear is acceptable on the Retainer 8N4124B. I have a small amount of wear on the outside inner face. Thanks in advance.
Scott in Chino Valley
05-17-2003 17:00:40
 Re: Rear axle retainer in reply to Pj 8N Wy, 05-17-2003 16:07:14
As long as the inside (bearing side) of the retainer isn't damaged, and it doesn't interfere with the cork seal, the wear on the outside of the retainer shouldn't be a problem. When the hub gets loose on the axle, it can rub up against the retainer causing the wear. I recently rebuilt mine (including new axle and hub) and thought the retainer might be bad because of the wear. I paid $35 for a used one (I don't think you can get new ones any more) and it was in worse shape than the one I had. I ended up using the old one and have not had any problems.
