Part time spark on one cylinder
Alan
05-18-2003 18:19:23
1947 2N Ford. We changed cap, rotor, points, coil, spark plugs, condensor, and spark plug wires. Number 4 cylinder has light spark, sometimes it has good spark. What could it be? We even changed some of these parts twice within a week. Nothing helped. Two years ago changed over to 12 volt system with resistor block. Please post message if anyone has any ideas to fix this problem. Thank You
bg
05-18-2003 22:43:59
 Re: part time spark on one cylinder in reply to Alan, 05-18-2003 18:19:23
If you have good wires and good plugs and a good cap and rotor and all connections between the cap and plugs are good, I'd suspect a worn rubbing-block cam lobe in the distributor, a bad distributor shaft bushing or bent shaft. Even a slight wobble could make for erractic spark.
Rusty
05-18-2003 18:40:20
You say only number four has light spark. Look at the sparks on the other cylinders. A good spark on the other cylinders means a bad plug or wire on number four. You need a good white blue spark.
