Order Ford 8N Parts Online
Will my 8N handle a 7 ft finishing mower?
8Nebraska
05-21-2003 18:30:03
Or should I stick to a 6 footer?
Does side or rear discharge make a difference in power requirements?
Jim WI
05-22-2003 12:44:46
 Re: Will my 8N handle a 7 ft finishing mower? in reply to 8Nebraska, 05-21-2003 18:30:03
I've a 6-foot King Kutter on a 2N. I think it would handle a 7-footer in normal mowing conditions. The problem is that there's a BIG jump in price to go to a 7-footer. In the KK line, the 6-foot is available in two versions -- a single belt and a double belt. The double belt costs about 40% more than the single belt. The 7-foot is only available in the double belt version so as you can imagine, the price of that extra foot is quite a bit more.
Given that the single belt 6-foot mower will slip if you let the grass grow a little longer than normal, I suspect a single belt 7-foot mower would be nearly unusable.
TJW
05-22-2003 11:20:05
I agree with the other guys...the 6 foot is a good size for the 8N because it is just a few inches wider on each side than the tires.
This means you can mow your yard just like a riding mower using your front tires to line you up from row to row....works great!!!
I think a 7" might be a tad clumsey as well...
TJW
Gary B
05-22-2003 10:25:57
I use a 6 ft. King Cutter finishing mower. I seldom have problems with power. Tall grass along with too much speed, however, will cause belt slippage. The resulting reduced blade speed will cause the unit to plug up. I normally mow in 2nd gear, using first gear in the tall stuff. Even then I will occasionally get plugging. The solution then is to cut a narrower swath until out of the tall stuff. I am glad I didn't get the 7 footer, unless I got the double belt option, which was pretty expensive if I remember right.
Just my experience.
Gary
Philip
05-22-2003 05:08:11
John, I pull a Woods RD7200 6' rear discharge finish mower behind my 8N. I cut every other week the area away from our house. I doubt if an N could pull a 7' mower. Maybe if you cut every 5 days. I have never heard of anyone pulling a 7' mower with an N either. Philip.
