Stuck draft control
Richard Fazio
05-24-2003 06:02:24
I rebuilt the hydrolics in my 48 8N. They are working great now. When I had it apart the underside of the lift cover was a little rusty from sitting for many years. I cleaned it up good and greased everything. Before I put it back together I made sure the draft control lever was working ok because it seemed to be sticking. Once clean and greased it was fine. I switched it back and fourth a few times once together to confirm the lift was doing the correct thing, which it was. Now it apears to be stuck in the position control spot, up. What's the trick? Does it move easier when the lift is in certain positions? Or what did I forget when I had it apart.
