Dell need your help please!
BOB
05-25-2003 18:22:38
Dell i know this is the ford board but i have a farmall super A that has been converted to 12volt with the gm alternator 1-had a power resister on the I terminal (ceramic looking thing) with real thin solid wire at both ends. this keep breaking on me.
2-so i put the gm #194 lamp and socket in its place seem more talorable to breakage
3-tractor does charge like it should with this light set-up
4-what does this light do ? turn on alternator or excitor?
5-thanks for all replys
6-just trying to understand this electric stuff
BOB
Ron/PA
05-26-2003 04:28:47
 Re: Dell need your help please! in reply to BOB, 05-25-2003 18:22:38
Bob, does your Super A have a magneto? I just assumed they all did, if it does, then all you are doing is converting the charging system. If it has a distributor,,,, then I just learned sumpin new about Donna's lawn mower which I converted to 12 volts about 12 years ago for the lighting system. Later
Ron
RON ---NO MAG JUST A DIST
05-26-2003 10:06:48
 Re: Re: Dell need your help please! in reply to Ron/PA, 05-26-2003 04:28:47
THANKS BOB
THANKS Dell YOU ARE THE M
05-25-2003 18:54:51
BOB :)
MAN
05-25-2003 18:56:39
 Re: Re: Dell need your help please! in reply to THANKS Dell YOU ARE THE M, 05-25-2003 18:54:51
I dont know what happen there? BOB
Prentice
05-25-2003 18:53:01
Forget the idiot light, go buy a universal auto ignition switch and run the P1 wire to the accessory terminal on the switch. Problem solved, no extra light to mount.
Dell (WA)
05-25-2003 18:59:50
 Re: Re: Dell need your help please! in reply to Prentice, 05-25-2003 18:53:01
Prentice..... ..ah yes, one of my other 8-ways to do 12 volt conversions..... ...Dell, who answered the question
Dell (WA)
05-25-2003 18:42:34
Bob..... ....you can't hang a heavy ceramic power resistor from small solid wires and NOT have it break on you. You have to physically support the heavy HOT power resistor and NOT dangle it.
I'll make a guess that that resistor you are refering to is a 10 ohm 10 watt power resistor, used to electrically isolate the P-1 "excite" alternator terminal so you can turn OFF your engine when you turn-off the ignition switch.
The gm #194 trailer marker lamp used as an "idiot light" does the same thing, electrically isolates the P-1 alternator terminal.
Eather one works just fine for isolating the alternatore P-1 "excite" terminal.
Infact they are just 2 of 8 ways that I know of to isolate the excite terminal so your tractor turns off..... ...Dell
