Put those resistors in parallel.
Rob
05-26-2003 11:54:08
Coil voltage came up just more then 1/2v so now I have 3v. It starts with out any choke! I suppose lapping the valves in #1 and #2 had to help. Compression is still low on all four. At or under the 90psi spec. Well, if you look at the gage from one side it reads 90 on two of them, almost....
The cylinder walls are stained and I suppose pitted. Probably set for a long time with condensation in there. On top of that it's like 0.015 inch piston to cylinder wall, way out of spec.
I'll see if it starts easier this winter.
